02-19-2014 08:05 AM - edited 07-05-2021 12:13 AM
Does anyone know what the CLI commands are for a WLAN
I know that "wlan security wpa wpa2 ciphers aes enable 1" enables WPA2/AES, but how do you add CCKM?
Also, does anyone know the PSK command for WPA2 AES?
Best Regards,
John
Solved! Go to Solution.
02-19-2014 08:27 AM
config wlan chd
config wlan dhcp_server
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
02-19-2014 08:27 AM
config wlan chd
Scott
02-19-2014 08:41 AM
Try this:
config wlan security wpa akm cckm enable
Scott
02-19-2014 09:53 AM
Hi Scott,
So, if I use the following:
wlan dhcp_server 3 0.0.0.0 required
It means DHCP Server Required using WLAN 3 and utilizes the DHCP server configured on the interface for the VLAN where the guest users are located?
i.e.
config>wlan dhcp_server 3 ?
Best Regards,
John
02-19-2014 09:55 AM
If you just want to enable DHCP required on the WLAN, then its best to configure that on the GUI. The only way you can configure DHCP required from the CLI is if you specify the DHCP server address. This can be a dhcp server or your guest anchor wlc if that is doing dhcp.
Scott
02-19-2014 12:05 PM
Hi John,
Yes, If you use 0.0.0.0 then it is equivalent to just tick " DHCP address assignment Required" in GUI
Refer this for more details
http://mrncciew.com/2013/05/17/wlan-config-via-cli-part-5/
Rasika
*** Pls rate all useful responses ****
