Community Member
Configure WISM controller Vlan Management
Anyone can clarify me if is correct or not to confifure the WISM controller on a 6509 management in VLAN1 or is a must to put ( as Cisco Described : http://www.cisco.com/en/US/docs/wireless/technology/wism/technical/reference/appnote.html#wp40841 ) in VLAN 40 or any aother VLAN different by Vlan 1 ?
This question because now we found a broadcast storm passing through VLAN 1 and through the wirelles network
Thanks !
Silver
Re: Configure WISM controller Vlan Management
No, its not necessary it just gives the example.
Community Member
The question was : can I use Vlan 1 or I have to change it to another "non default" VLAN ?
you an use whatever VLAN you wish. If all of your network is managed via VLAN 1, than that is fine. I know that some people recommend not using VLAN 1, but that is a personal call.
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
183
