Connecting a AIR-LMC352 to an AIR-ANT3549?
Is it possible to connect a AIR-LMC352 to an AIR-ANT3549 and if so what part or manuf. cable would you use to conenct the MMCX on the card to the RP-TNC connector on the antenna?
My hope is to use this to communicate back to a 350 Series bridge in AP mode with the same AIR-ANT3549 antenna connected to it and since I'm looking at a distance of about 1500 feet - I'm assuming I'd need the LMC352 with matching antenna to reach back to the bridge instead of the integrated client adapter...
Thanks!
- Ken
Re: Connecting a AIR-LMC352 to an AIR-ANT3549?
I'm sorry - I didn't notice I was in the wrong forum when I posted this - please ignore and i'll post it in general - very sorry :-/
- Ken
Ken,
I can get you some part-numbers for custom MMCX to RP-TNC or any other connector that you need.
David Fulgham
ComGuard CTS Ltd.
867-979-3292
david@comguardcts.com
175
