Community Member
continuos loss of parent association and authentication (350 bridge)
Hello!
We recently purchased the 350 series bridges and set one to be root and the other to be non-root.The root bridge has a 13.5dbi yagi connected to it. The yagi is mounted on a roof that resembles a small house.The non-root bridge is mounted in a crane that has an omni directional antenna ( 12 dbi ).It is mounted quite high.The yagi antenna was eyed up with the omni directional antenna.The antenna alignment test was done from the crane that showed a fairly good signal strength and quality.The carrier test showed varying noise in the middle frequencies.I set the channels both bridges to be channel 6 with the opportunity to find less congested channels.These are the root and the non root log files.It would be great if someone could give me some pointers on why it is doing this. Much appreciated.
Anonymous
N/A
Re: continuos loss of parent association and authentication (350
Try giving yes tor data rate basic and also give Loss of backbone connectivity to No action.
Community Member
Hi !
Thanks for taking the time to read and respond.
From what you told me, I cannot find the setting in the 350 bridge software about loss of backbone connectivity.
Can you let me know where it is?
Much appreciated....
Community Member
There was a software bug in the early 12.x VxWorks software that could be the problem. We had a similar problem and it was fixed when we upgraded the software to 12.03. Hope this helps.
201
