Data Rates 7921
What is best pratice for 802.11a data rates and a cisco 7921, standard and mandatory.
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
Re: Data Rates 7921
We recommend 12 as the minimum, basic (mandatory) rate and then can optionally enable the higher rates (18-54).
This accounts for capacity and range.
However the 36-54 rates can also be disabled as they do not provide any capacity or throughput advantages for voice.
See the 7921G Deployment Guide for more info.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7921g/6_0/english/deployment/guide/7921dply.pdf
Re: Data Rates 7921
Mig,
Thanks as always. Is there any good documents how to ready the traces from a 7921 ? I understand most of the traces, but would like a document if there is one.
Thanks!
Re: Data Rates 7921
No not really. Only how to enable the modules and what each module is for.
218
