DTPC on Autonomous AP
I can't seem to get DTPC working on an Autonomous AP.
AP 1240 2.4Ghz radio running 12.4(10b)JDA (I didn't find any related bugs in bug toolkit)
Config:
dot11 ssid test
authentication open
guest-mode
admit-traffic
dot11 phone dot11e
interface Dot11Radio0
ssid test
power local 14
power client 14
channel 2412
station-role root
dot11 qos class voice local
admission-control
admit-traffic narrowband max-channel 75 roam-channel 6
dot11 qos class voice cell
admission-control
world-mode dot11d country US both
bridge-group 1
I got a 7921 associated phone connected to the callmanager.
AP1240A#show dot11 associations 001e.4a3e.e361
Address : 001e.4a3e.e361 Name : SEP001E4A3EE361
IP Address : 3.45.47.134 Interface : Dot11Radio 0
Device : CP-7921 Software Version : NONE
CCX Version : 4 Client MFP : Off
State : Assoc Parent : self
SSID : test
VLAN : 0
Hops to Infra : 1 Association Id : 2
Clients Associated: 0 Repeaters associated: 0
Tunnel Address : 0.0.0.0
Key Mgmt type : NONE Encryption : Off
Current Rate : 54.0 Capability : WMM ShortHdr ShortSlot 11h
Supported Rates : 1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
Voice Rates : disabled
Signal Strength : -51 dBm Connected for : 2942 seconds
Signal to Noise : 42 dB Activity Timeout : 57 seconds
Power-save : On Last Activity : 2 seconds ago
Apsd DE AC(s) : BK BE VI VO
Packets Input : 751 Packets Output : 674
Bytes Input : 47227 Bytes Output : 53088
Duplicates Rcvd : 0 Data Retries : 75
Decrypt Failed : 0 RTS Retries : 1
MIC Failed : 0 MIC Missing : 0
Packets Redirected: 0 Redirect Filtered: 0
On the phone I go to: Settings > Device Information > WLAN > TX Power is 5 dBm, I would expect it to be at 14dBm
AP1240A#show controllers d0
Configured CCK Power: 14 dBm
Configured OFDM Power: 14 dBm
Active power levels by rate
1.0 to 54.0 , 14 dBm
OffChnl Power: 20, Rate 1.0
Allowed CCK Power Levels: -1 2 5 8 11 14 17 20
Allowed OFDM Power Levels: -1 2 5 8 11 14 17 20
Allowed Client Power Levels: 2 5 8 11 14 17 20
I did a Wireshark capture with AirPcap and I'm looking at the advertised beacon:
Tagged parameters
Country Information: Country Code: US, Any Environment
Tag Number: 7 (Country Information)
Tag length: 6
Tag interpretation: Country Code: US, Any Environment
Start Channel: 1, Channels: 11, Max TX Power: 26 dBm <<< shouldn't it be 14 dBm?
this is strange, I'm going to try a different IOS image
Hall of Fame Super Gold
Re: DTPC on Autonomous AP
HTML into your AP. Go to Network Interfaces > Click on the Radio > Settings Tab.
Change the settings for CCK Transmitter Power and/or OFDM Transmitter Power.
Hope this helps.
The 7921 phone can throttle back the tx power if the current rx signal is strong. This is an algorithm to prevent unnecessary noise in other areas and to conserve the battery.
You can see that you have a strong signal.
Try stepping a bit away from the AP (i.e. -67 dBm) and you should see the correct value.
893
