Community Member
Error update images for Wireless Controller WLC 2500
I have problem When I want to update images for Wireless Controller WLC 2500,
I choose number 6 when Boot Loader Menu shown.
For your attenttion, thankyou.
 Boot Loader Menu
 1. Run primary image (Image not found) - Active
 2. Run backup image (Image not found)
 3. Change active boot image
 4. Clear configuration
 5. Format FLASH Drive
 6. Manually update images
Enter selection: 6
Launching...
Launching images...
init started: BusyBox v1.6.0 (2009-02-03 04:56:32 EST) multi-call binary
Mount failed for selinuxfs on /selinux:  No such file or directory
starting pid 655, tty '': '/etc/init.d/rcS'
Use DHCP for ip configuration (Y/n)? n
Enter switch IP address: 192.168.1.12
Enter switch netmask: 255.255.255.0
Enter switch gateway: 192.168.1.10
Enter TFTP server IP address: 192.168.1.10
You have entered:
     IP Address     : 192.168.1.12
     Netmask        : 255.255.255.0
     Gateway        : 192.168.1.10
     Server Ip Addr : 192.168.1.10
Is this correct(y/N)? y
!!! WARNING updating using .aes or unapproved files will disable this unit !!!
Do you want to update RTOS (y/N)? y
Do you want to update Primary Or Secondary Image (P/s)? P
Enter filename for RTOS update: AIR-CT2500-K9-1-8-0-0-FUS
Everyone's tags (4)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
but from where I can download
but from where I can download the RTOS image?
Cisco TAC can publish the RTOS image.
should I use RMA service for sofware fail?
This is normal.  You can RMA the unit.
That is not a valid RTOS image.
You have two choices:  Contact TAC and ask for an RTOS image or you get your appliance RMA-ed.
Community Member
thankyou for your answer, but
thankyou for your answer, but from where I can download the RTOS image?
should I use RMA service for sofware fail? I think this not serius problem.
1300
