Community Member
Fax connected to FXS get's busy
We have a remote site with a 2811 running 12.4(13r)T
There are 4 BRI ports and 2 FXS ports.
I have a fax connected to fxs 0/1/0
The dial-peers are configured like this :
dial-peer voice 7575 pots
destination-pattern 7575
port 0/1/0
The voice-port has the default configuration :
voice-port 0/1/0
voice-port 0/1/1
I can see when calling the fax number from a mobile phone that the BRI port becomes active
and the fxs goes to ringing :
CHSOSANyonISR#show voice port summary
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
0/1/0 -- fxs-ls up up on-hook ringing y
0/1/1 -- fxs-ls up dorm on-hook idle y
0/2/0 1 bri-voice up dorm none none y
0/2/0 2 bri-voice up dorm none none y
0/2/1 1 bri-voice up dorm none none y
0/2/1 2 bri-voice up dorm none none y
0/3/0 1 bri-voice up dorm none none y
0/3/0 2 bri-voice up dorm none none y
0/3/1 1 bri-voice up up none none y
0/3/1 2 bri-voice up dorm none none y
50/0/1 1 efxs up up on-hook idle y
50/0/2 1 efxs up up on-hook idle y
50/0/3 1 efxs up up on-hook idle y
50/0/4 1 efxs up up on-hook idle y
50/0/5 1 efxs up up on-hook idle y
50/0/6 1 efxs up up on-hook idle y
However, I get a busy tone directly after this.
Any help will be much appreciated.
Rgds,
Jeroen
1 REPLY
Community Member
Re: Fax connected to FXS get's busy
sorry, wrong place to post. will port in correct forum
170
