Filtering on CISCO 350 (a)
I'm trying to set up filters on a CISCO 350 and am a bit confused with the configuration.
1) Is it so that the "Default disposition" defines how all protocols will be handled while for each protocols defined in the "special cases" in a filter set definition, another action "per protocol" can be defined (kind of :DISCARD ALL but FORWARD only ones in Special cases)
Thanks and best regards,
Guy
Re: Filtering on CISCO 350 (a)
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
You are correct. The default disposition allows you to define the general case. Allowing you to block (default disposition) all, but forward (filter) special cases (filter), or forward (default disposition) all, and block (special cases) special cases
170
