Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Guest vlan on single AP
I have got a single Cisco AP 1142N and want to setup a guest WIFI. We have our production one working but don't want clients to connect to this.
I have got a basic config as shown attached.
i want to make the guest network in 172.16 range.
when looking around on cisco forums i have seen configs but they have not worked for me. I have tried the link below
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080665ceb.shtml
this ap will connect to a layer 2 2960 then into an ASA out to the internet.
James
1 ACCEPTED SOLUTION
you should be able to ACL that, but you might want to ask that question on the FW forums.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
what you need to do is add dot1q subinterfaces and VLAN to the SSID for this to work.
as a for example
dot11 ssid corp
vlan 10
dot11 ssid guest
vlan 20
dot0.10
encapsulation dot1q 10 native
dot0.20
encapsulation dot1q 20
Gig010
gig020
encapsualtion dot1q 20
Which ever vlan you call "native" is where the AP will pull its IP address from.
Rinse repeat that for all SSID and Radio.
Then on the switch port change it from access to a trunk an call the native vlan
HTH,
Steve
I got the guest vlans working which i used as vlan 10 and the production vlan 1 ( native )
Im plugging direct into a Cisco ASA 5505 POE port7
i want just to allow the guest network to have internet and not be able to access the internal.
the ASA will act as the DHCP range for both vlans
vlan 1 will 192.168.70.0 /24
vlan 10 guest 172.16.10.0 /24
if this possible with the ASA 5505 as i know you don't have any sub interfaces so confused on how to do this?
it should work if you can dot1q trunk the interface on the ASA
HTH,
Steve
am i correct in saying we cannot do this as the 5505 ports are all layer 2?
All setup and working. Now i need users from the guest vlan to access the printer in the production which is on 192.168.70.20 and nothing else. Can this be done? have tried access list and it doesn't seem to be working?
HTH,
Steve
Thanks. I have now opened this in the FW forums. i will update with the correct anwser shortly.
1504
