help using Custom ssl cert in Aironet https web Interface
I spent a few hours learning how to import certificates, and I think I did ok with that part. If I use the selfsigned cert when HTTPS is enabled through the web interface, HTTPS works just fine, but the second I
ip http secure-trustpoint test
I get a connection reset error in my test browsers.
ip http secure-trustpoint TP-self-signed-3349201592
doesn't fix it, it just gives me an "invalid certificate" error. I'm going to include what I did to get to where I am now, and hopefully you can see where I'm going wrong.
In Linux:
openssl genrsa -out test.key 2048
openssl req -new -nodes -key test.key -out test.csr
got csr cert and root ca from CACert
openssl rsa -in test.key -des3 -passin pass: -out keyout.pem
password:12345678
scp root.ca root@10.0.0.20:flash:/root.ca
scp keyout.pem root@10.0.0.20:flash:/test.key
scp test.crt root@10.0.0.20:flash:/test.crt
In Aironet IOS
crypto ca trustpoint test
crypto ca import test pem url flash:/test 12345678
% Importing CA certificate...
Source filename [test.ca]? root.crt
Reading file from flash:root.crt
% Importing private key PEM file...
Source filename [test.prv]? test.key
Reading file from flash:test.key
% Importing certificate PEM file...
Source filename [test.crt]?
Reading file from flash:/test% PEM files import failed.
ok so that didn't work, but I can see that the root.crt imported at least
show crypto ca trustpoints
Trustpoint TP-self-signed-3349201592:
Subject Name:
cn=IOS-Self-Signed-Certificate-3349201592
Serial Number: 01
Persistent self-signed certificate trust point
Trustpoint test:
Subject Name:
ea=support@cacert.org
cn=CA Cert Signing Authority
ou=http://www.cacert.org
o=Root CA
Serial Number: 00
I then tried to import just the keypair
crypto key import rsa test pem url flash:/test 12345678
% Importing public key or certificate PEM file...
Source filename [test.pub]? test.crt
Reading file from flash:test.crt
Reading file from flash:test.key% Key pair import succeeded.
Strangely, that worked, and now I have my keypair.
show crypto key mypubkey rsa
% Key pair was generated at: 03:39:07 GMT Jul 29 2009
Key name: BenCloud
Usage: General Purpose Key
Key is not exportable.
Key Data:
30820122 300D0609 2A864886 F70D0101 01050003 82010F00 3082010A 02820101
00CAC0D9 4C79D716 140D38BF C97C1120 8A0FDCED DDDF5438 8A4BDC5C 00629676 .......
Now to apply it to the trust point, I also tried to mimick the selfsigned TP's settings, and this is what I ended up with
show
enrollment selfsigned
subject-name cn=CA Cert Signing Authority
revocation-check none
rsakeypair test
end
vs
show
subject-name cn=IOS-Self-Signed-Certificate-3349201592
rsakeypair TP-self-signed-3349201592
end
Then I tried applying this new TP to the HTTPS server
Which caused the error I discribed earlier
Silver
Re: help using Custom ssl cert in Aironet https web Interface
If the browser produces an "invalid certificate" error, delete the router's certificate from the browser's certificate store (if it was saved there), or restart the browser (if the certificate was accepted temporarily).
That isn't the problem, it says "The connection was interrupted" when I use my own Trust Point.
As I said, if I disable HTTPS, then reenable it, through the WebUI, it regenerates the self signed keys and works just fine. I think I'm assigning the keys incorrectly, but I don't know where I'm going wrong.
603
