How to Verify for WLAN for WMM
Adnan Khan
Level 4
Level 4
How to verify that my Wireless card is WMM certified?
Stephen Rodriguez
When you go into the properties of the card you should see a WMM section that you can set to disabled or enabled. Of your card is a/b/g/n OT supports WMM as it is needed to gain the N rates.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Stephen Rodriguez
Steve
HTH,
Steve
I want to capture 802.11 frames using Linksys WUSB600N ver 1, ver 2 (Dual-band USB adapter and Omnipeak
Please guide me how i can do that?
