IOS Root and WGB Connectvity
john.rossi.st
Hi Experts,
What are the implications of blocking band 3 between a WGB and Root using the "dfs band 3 block" command. Note, this is enabled by default on IOS AP's as stated below. Does it in anyway affect the use of 802.11n MCS rates?
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/ios/release/notes/b11jar1n.pdf
The 1, 2, 3, and 4 options designate blocks of channels:
1—Specifies frequencies 5.150 to 5.250 GHz. This group of frequencies is also known as the UNII-1
band.
2—Specifies frequencies 5.250 to 5.350 GHz. This group of frequencies is also known as the UNII-2
band.
3—Specifies frequencies 5.470 to 5.725 GHz. By default, this group of channels is blocked from
DFS selection.
4—Specifies frequencies 5.725 to 5.825 GHz. This group of frequencies is also known as the UNII-3
band.
This is the command that appears in a default configuration:
ap(config-if)# dfs band 3 block
Best Regards,
John
Scott Fella
It doesn't affect MCS rates. Those channels are uni-2 extended which many devices don't support these days. That is fine not being used. Better that way:)
-Scott
Scott Fella
-Scott
