ip-to ip Call with Cisco ?
merryadoc
I?m seraching for a cisco product.
Mobile -Phone
Wireless Lan
Ip-to-ip Call possible from one phone to another. I?d like to change the "walky-talkeys" against those phones. Theres one from siemens SL75-Wlan which is .. well just crap, it freezes and has lot more issues. So we?re using cisco access-points would be great if theres a phone from cisco to use direct ip calls.
Rob Huffman
Hi Kevin,
Have you looked into this Cisco product;
Cisco Unified Wireless IP Phone 7920 Version 3.0
From this doc;
http://www.cisco.com/en/US/products/hw/phones/ps379/products_data_sheet09186a00801739bb.html
Hope this helps!
Rob
Hi Rob,
the 7920 looks pretty good. I?m just not sure if it is possible to use the phones without a callmanager or gateway in between. In the Details of the Productsheed no word about direct ip call :( do you have experience with the 7920 and are sure about the features ?
Hi Kevin,
My bad!! I didn't understand (or can't read) your post. You definitely need Callmanager for the 7920. 20 lashes for me on this one :(
Sorry about that,
Rob
