Community Member
leap failure after equipment reboot
Everything worked fine, but afer a power failure all the equipment rebooted (3560, 1100, acs, wlsm).
No 7920 fails to authenticate using leap (cckm+tkip). All configs look ok (all of the had been saved)
PEAP clients and wep client authenticate without any problems.
And one more problem
despite this
dot11/wlccp authenticator:
receive packet debugging is on
transmit packet debugging is on
process debugging is on
dot11:
802.1X module LEAP debugging is on
ldk-d-3ap10#
the only messages I get are
Oct 3 10:41:13.043: %DOT11-7-AUTH_FAILED: Station 0011.21ce.da30 Authentication
failed
Any ideas?
1 REPLY
Community Member
Re: leap failure after equipment reboot
First impression would be that some config wasn't saved.
If using CCKM, need to ensure that 7920 is set to AKM and LEAP username and password are correct.
Would check the ACS logs to see if the request gets there or not. If so, should give a failure reason.
You can attach your AP config for review as well.
196
