LWAP 1010 and 802.11n
We are looking at upgrading a wireless network to for 802.11n. If we upgrade the 4402 WLC to support this, would the older AP1010 access points support 802.11n wireless?
Re: LWAP 1010 and 802.11n
You will need an 802.11n Ap to support 802.11n (with full capabilities).
You can support 802.11n client but only at the 802.11b/g or 802.11a datarates.
According to the Ap´s you buy it´s more probably you can not use these APs (ap 1010) due to the use of sofware that support the newer ap´s but not the older.
Airespace 1010 is supported until release 4.2
Best regards.
Hall of Fame Super Gold
APs that support 802.11n are the following:
1040, 1140, 1250, 1260 and 3500i/e.
NOTE that the 1260 and the 3500 will only support antenna gain of up to 6 dBm.
339
