No audio between two 7920 phones when vlan is configured on Access Point
Hi Folks,
I have configured two 7920 wireless IP phone with CME installed on 2651XM router, and associating the 7920 Wireless IP Phone with 1200 Cisco Access Point.
Without VLAN configured on the Access Point , the two phones can establish a call and the voice is hared from both side without any problem.
As soon as I configure VLANs on the access point , problems get started, here is the exact symptoms :
1 – no audio can be hared when a call is made between two 7920, although I can ring the other 7920 and it shows connected on the LCD but without any audio.
2 - there is no problems If I call between a 7920 phone and 7912 phone, the audio can be hared in both directions.
Thanks Allot
Here is the configuration of the AP
ap#show run
Building configuration...
Current configuration : 3291 bytes
version 12.3
no service pad
service password-encryption
hostname ap
ip subnet-zero
no aaa new-model
dot11 vlan-name Data vlan 3
dot11 vlan-name Management vlan 1
dot11 vlan-name Voice vlan 2
dot11 arp-cache
class-map match-all _class_Data-Packets0
match ip precedence 0
class-map match-all _class_Voice-Packets0
policy-map Voice-Packets
class _class_Voice-Packets0
set cos 0
policy-map Data-Packets
class _class_Data-Packets0
set cos 0
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 2 key 1 size 128bit 7 E6050B0DB7423C1AAEF307F0D9D8 transmit-key
encryption vlan 2 mode wep mandatory
ssid data
vlan 3
authentication open
ssid management
vlan 1
authentication open
ssid voice
vlan 2
authentication open
short-slot-time
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
power local cck 20
power local ofdm 20
power client 20
channel 2437
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
service-policy input Data-Packets
service-policy output Data-Packets
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 2
service-policy input Voice-Packets
service-policy output Voice-Packets
no ip route-cache
bridge-group 2
bridge-group 2 spanning-disabled
interface Dot11Radio0.3
encapsulation dot1Q 3
no ip route-cache
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
bridge-group 3 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.2
ip address 172.16.1.100 255.255.255.0
no ip route-cache
bridge-group 2
no bridge-group 2 source-learning
interface FastEthernet0.3
no ip route-cache
bridge-group 3
interface BVI1
no ip address
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
logging snmp-trap emergencies
logging snmp-trap alerts
logging snmp-trap critical
logging snmp-trap errors
logging snmp-trap warnings
bridge 1 route ip
Re: No audio between two 7920 phones when vlan is configured on
Sorry for the spelling heard not hared :)
To add more notes: the switch is connected to the access point via the port 1/0/45 and the switch is connected to the CME router via 1/0/17 and to the remaining IP Phones via 1/0/46 and 1/0/43
Let me post the configuration of the switch:
Switch#show run
Current configuration : 2411 bytes
version 12.2
hostname Switch
switch 1 provision ws-c3750-48p
ip subnet-zero
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet1/0/17
switchport access vlan 2
interface FastEthernet1/0/41
interface FastEthernet1/0/42
interface FastEthernet1/0/43
interface FastEthernet1/0/44
interface FastEthernet1/0/45
switchport trunk allowed vlan 1-3
switchport mode trunk
switchport nonegotiate
interface FastEthernet1/0/46
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address 172.16.1.150 255.255.255.0
interface Vlan3
ip address 192.168.80.1 255.255.255.0
interface Vlan30
no ip address
For the ap config, should add the following to the radio interfaces for vlan 2, where X matches the bridge #.
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 unicast-flooding
Also usually would put IP for mgmt on BVI which maps to native VLAN.
Should work after applying this change as these phones are in the same VLAN, so no routing is needed.
Also should unshut int vlan 1, since you are using that VLAN in your network. Otherwise change the 1/0/45 to vlan 2 and make that the native vlan on the AP side as well.
Thank you , it is working great now, I was also missing many other items such as setting the data rate to 11 Mbps as required and the more higher data rates as enable, also my COS was set to 0 , it should be set either to 5 or 6.
Thanks again
234
