Not able to Print Using IPAD 2 with CISCO Leight Weight ACCES Point
ranjit123
Level 3
Level 3
Dear All,
We have recently connected a IPAD 2 in our wireless N/W, it works perfectly fine.
But when we are tyring to use its AIRPRINT function its just not detecting the HP PRINTER.
But when we connect the HP printer to a DLINK device then the IPAD is able to detect the printer and AIRPRINT is happening.
Is ther any setting on the AP or WLC ( 4400) to detect the Printer
Kindly Check
Ranjit
Probably broadcast forward enabled and multicast setup, AirPrint uses the bonjour protocols as well.
8 Replies 8
phoenix7799
Dear Ranjit,
Is the HP and Ipad on the same subnet? Could you specify the ip of those?
Dear Marco,
Both are on the same subnet
IP of IPAD ;--> 10.0.19.49/24
IP of Printer ;---> 10.0.19.69 /24
the IPAD is not able to detect the printer in wireless setting
Could you please verify the Cisco WLC configuration? Let me know in private if you want mp@marcoprovenza.com
Dear All,
Same is working now.
Ranjit
good work!!!
ranjit23,
What was the fix?
Justin
... typd on tny kybrd.
Dear Blakekrone ,
You are absolutely right; we just enabled Multicast on the cisco AP and it started working.
Ranjit
