Community Member
One-Way QoS Markings
Hi All,
Have just put the QoS configurations on the WLC for a Voice WLAN and Can see that the Phone is setting the QoS Marking on frames from the 7921G to the WLC with the following :
QoS Control
Priority: 6 (Voice) (Voice)
Ack Policy: Normal Ack (0x00)
Payload Type: MSDU
Transmit Opportunity (TXOP) Limit Requested: 0x00
But on the way back, the QoS Marking are best efforts. I also notice the EOSP change from 0 to 1.
QoS Control
Priority: 0 (Best Effort) (Best Effort)
...1 .... = EOSP: End of service period
Payload Type: MSDU
QAP PS Buffer State: 0x0
or
QoS Control
...0 .... = EOSP: Service period
Payload Type: MSDU
Can anyone understand why this would be?
Many thx indeed,
Ken
1 ACCEPTED SOLUTION
Community Member
Re: One-Way QoS Markings
Hi Ken,
the WLC uses / translates the DSCP and 802.1p markings of the arriving packet from the LAN. So you should implement QoS in the LAN, too, anyways.
Here is the corresponding chapter from the VoWLAN Design Guide:
http://www.cisco.com/en/US/docs/solutions/Enterprise/Mobility/vowlan/41dg/vowlan_ch2.html
Figure 2-22 describes the whole translation process very detailed.
A WLAN Client supporting WMM sets an 802.1p value. When encapsulated into an LWAPP packet by the AP, the AP translates this 802.1p value to a corresponding DSCP value for the LAN Infrastructure to handle it correctly.
A packet from a non-WMM supporting WLAN Client will be set to the value which is set in the QoS-Profile on the WLC.
But if a packet arrives at the WLC from the LAN Infrastructure. the WLC uses the incoming QoS-value and translates i if needed.
Greets,
Sebastian
Community Member
Hi Ken,
is the underlying infrastructure (switches, etc.) QoS-enabled, too? I.e. is the switch marking the voice-packets with the corresponding QoS-values.
Otherwise, did you follow the VoWLAN Deployment Guide from Cisco? If not, check if WMM is enabled globally.
Greets,
Sebastian
Community Member
Hi Sebastian,
No the packets coming back to the WLC from the wired network are NOT marked correctly (well, reset to dscp 0).
I thought that the WLC may set the DSCP value itself when going "network downstream" to the AP?
I assume by your comments that it has to arrive at the WLC with the right classification ?
I will have to mark this :) just thought there was a clever feature of the WLC when setting the QoS profile to platinum?
I assume not, correct?
Many thx for your help :))
Ken
Community Member
Hi Ken,
Greets,
Sebastian
Community Member
Hi Sebastian,
Many thx indeed for your help
Kind regards,
Ken
391
