Portable battery pack
wams01
I'm looking for a portable battery pack to use with ap350 and br350 when doing a site survey. any recommendations, manufacturers, etc.?
5 Replies 5
dave.reid
I have no experience with this, I just know they have something.
http://www.terra-wave.com/Search.bok?category=Site+Survey+Tools
thanks for the info. that's exactly what I'm looking for.
I’m just curios if you bought the battery pack from Terra-Wave and if it worked together with the 350-serie? The specification of the battery pack says that it can deliver 5V and 12V (according to their homepage). My concern it that 350-units uses inline power and that the input power requirements for AP350 units are “24VDC 10% to 60 VDC (Ethernet line power)” compared to the AP340 that have a power consumption of 5V5% @ 800 mA.
I am looking for a battery pack that works with 350 units myself, and I would appreciate any comment of the topic.
The only product I have seen that should work together with AP350 is available here. http://www.ensign-net.co.uk/EWS/mainframe.htm
I have been using the Terra-Wave Battery pack with the Cisco 350 series access points for well over a year. I recommend also buying the mounting bracket with the battery.
lomanve
You could save yourself money by purchasing a battery pack from Batteries Plus (12V 5Ah) and what I did was use a Male and Female DIN connector to the wall wart and a Female DIN connector to the battery pack. This way you can use it with wall wart or battery pack. I picked up a charger too. Total investment: $46.00
