RRM min output power seeting
I am ruuning WiSM 4.2 and all APs are running with RRM. What I find is that sonme APs go as low as power 7 when in fact they should go to a min of 4 (the power setting I used for my site survey).
Is there a way (gui or cli) to force RRM to a "minimum output power" that could be set to 4 for example to avoid having the APs go down as low as 6 or 7?
I also want to avoid disabling RRM for abvious reasons.
Your help is greatly appreciated
Cheers
1 REPLY
Silver
Re: RRM min output power seeting
If you don't want to loose RRM functionality leave dynamic channel and power assignment enabled statically configure specific access point radios with a power setting. Refer following URL for configuring it. http://cisco.com/en/US/docs/wireless/controller/4.1/configuration/guide/c41rrm.html#wp1098949
139
