Community Member
SPA232D with other DECT Handsets
I have just gone onto the NBN and now am trying to get the phone services sorted.
I've bought a SPA232D came with the SPA-302D Handset.  I have that working fine calls in and out over VoIP.
I have a couple of DECT phones being Commander and Doro units.
The commander one Registered fine, I was able to get it to bring up a dial tone, I've done something I'm not sure what, now I get an Engaged Tone.
The Intercom works fine between the two.
Any suggestions.
1 REPLY
Community Member
I would recommend you re-post
I would recommend you re-post your question in the following forum:
https://supportforums.cisco.com/community/5961/ip-telephony
John
130
