Community Member
ssid pb
hi all;
i work with a uc520 and i want to configure 2 SSID with two vlan (1,2), i did the configuration but when i do a search for the two ssid from my laptop i didn't discover them, but i can discover the others,
i tried to configure guest-mode, but it accept only one guest-mode parameter, this is a show from my conf:
Building configuration...
Current configuration : 13367 bytes
version 12.4
no service pad
hostname UC520
boot-start-marker
boot system flash uc500-advipservicesk9-mz.124-11.XW7.bin
boot-end-marker
logging buffered 4096
no aaa new-model
dot11 ssid data-lan
vlan 1
authentication open
dot11 ssid voice
vlan 100
authentication open
guest-mode
ip cef
ip dhcp relay information trust-all
ip dhcp use vrf connected
ip dhcp excluded-address 10.1.1.1 10.1.1.10
ip dhcp excluded-address 192.168.10.1 192.168.10.120
ip dhcp pool phone
network 192.168.10.0 255.255.255.0
default-router 192.168.10.10
option 150 ip 192.168.10.10
ip dhcp pool data
import all
network 10.1.1.0 255.255.255.0
default-router 10.1.1.1
dns-server 84.x.31.5
ip host voip.meditel.ma 10.150.1.4
ip name-server 84.x.31.5
ip name-server 84.x.31.6
voice translation-profile test
translate calling 1
voice-card 0
no dspfarm
vtp mode transparent
username cisco password 0 cisco
archive
log config
hidekeys
vlan 100
name voice
translation-rule 1
Rule 1 2003 20209000
Rule 2 2000 20209000
Rule 3 2001 20209000
Rule 4 2002 20209000
Rule 5 2005 20209001
bridge irb
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 10.150.14.15 255.255.255.0
interface Integrated-Service-Engine0/0
ip unnumbered FastEthernet0/0.1
service-module ip address 10.150.14.14 255.255.255.0
service-module ip default-gateway 10.150.14.15
interface FastEthernet0/1/8
interface Dot11Radio0/5/0
no ip address
ssid data-lan
ssid voice
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0/5/0.1
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0/5/0.100
encapsulation dot1Q 100
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 spanning-disabled
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
Community Member
Re: ssid pb
Try entering those commands:
mbssid
dot11 ssid data-lan
mbssid guest-mode
dot11 ssid voice
mbssid guest-mode
The work for Cisco autonomous APs, but I don't know if they will work for US520.
Community Member
Re: ssid pb
yes, by default you can only configure one ssid to broadcast, you need to use mbssid-guest mode on both ssids, that way you are able to broadcast both
166
