Symbol Netvision Phone w/Cisco 1200 series Access Point
I am running 802.11b access point my phone can associate and get an ip address from my call manager but I keep getting "not registered" "registered". I and then I lose association to the access point. I have 2 vlans on one access point one for voice and one for data. Please let me know if someone has a work around or a fix.
Stan
Re: Symbol Netvision Phone w/Cisco 1200 series Access Point
are you seeing the phone become unassociated on the AP ?
do you see a lot of CRC errors etc ?
Yes the phone is becoming unassociated on the AP. I see a lot CRC errors. Every time I begin to dial an extension, that is when it becomes disassociated.
Stan
Stan,
Sounds like you have an interference problem.
What did your site survey show up in terms of other AP's and overlapping coverage areas ? Try a new channel that has the 2 channel separation from other busy channels and maybe even try a new/better placement of the AP
effectivly what you have now is the equivalent of pulling out the cable and plugging it back in constantly on a standard IP phone this means you will not be able to make calls
What firmware you running on the AP ?
I am currently running Release 12.2.11-JA1. I have only one Access Point on channel 1. This is in a lab enviroment.
try to configure the phone as an h323 gateway (add phone, type h323) in the call manager and check if this works. Officially the netvision phones are not verified by Cisco..
222
