Two voice SSIDs merging to single SSID on same interface
I have two seperate voice WLAN and want to merge them onto a single WLAN. One is running static WEP and the other is running WPA. I've created another WLAN on the same interface as the static WEP WLAN to merge both voice WLANs to which is running WPA. With all the WLANs running platinum QOS, will that overfill the interface queue? If so, how can I increase the size of the queue to compensate?
1 REPLY
Gold
Re: Two voice SSIDs merging to single SSID on same interface
Just adding another WLAN won't overload the buffers, it depends on how many clients there are going to be.
244
