Hi ,
i have UC540 pbx and want to configure multi ssid and map each ssid with vlan...
the problem is , i cant put more than 1 ssid under the interface 0/5/0
!!!!to add
here is when i try to add another ssid undert the dot11 radio 0/5/0 interface :
UC540-CORE(config-if)#ssid abcd
No more than 1 SSIDs can be configured for Dot11Radio0/5/0
anyhelp ??
UC540-CORE#sh version
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.1(4)M4b, CIBU Special
Small Business Support: http://www.cisco.com/go/smallbizhelp
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Fri 18-May-12 15:06 by CIBU
ROM: System Bootstrap, Version 12.4(24r)SB, RELEASE SOFTWARE (fc1)
UC540-CORE uptime is 1 week, 2 days, 15 hours, 37 minutes
System restarted at 12:27:41 PST Sun Aug 31 2014
System image file is "flash:uc500-advipservicesk9-mz.151-4.M4b"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco UC540W-FXO-K9 (MPC8358) processor (revision 0x100) with 235520K/26624K bytes of memory.
Processor board ID FGL175223RL
MPC8358 CPU Rev: Part Number 0x804A, Revision ID 0x20
30 User Licenses
10 FastEthernet interfaces
2 terminal lines
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
4 Voice FXS interfaces
1 Voice MoH interface
1 802.11 Radio
1 cisco service engine(s)
128K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 UC540W-FXO-K9 FGL175223RL
regards
