voice gaps in 7921 when roaming between cisco APs controllers
Hi all
i have a problem with the voice calls when roaming between aps (1130). my controllers are on version 4.2.61.0. is there something i can do on the configuration side to fix this? the phone just goes quite (silent) but the call doesnt get dropped, it remains active.
I have seen a similar question here on the blog, but i doesnt give more clarity on what i should do to resolve this...
Your feedback will be highly appreciated
Re: voice gaps in 7921 when roaming between cisco APs controller
I would suggest to upgrade to 5.2.193.0.
Also ensure the 7921 phones are running firmware 1.3(2) or later.
See the 7921G Deployment Guide for more info.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7921g/6_0/english/deployment/guide/7921dply.pdf
I just had this same issue. You can create a syslog under advance on the phone and see the actual roam times. It should be under 150ms.
What i did to reslove my issue --
* Upgarded phones to 1.3.3
* Upgarded controllers from 42.176 to 4.2.207
I also reviewed the power levels on the aps and adjusted as needed.
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
i cannot see/find the advance option on the phone (7921G). is this configured on the phone?
can you provide me with a screenshot for setting up the syslog on the phone?
Lucky
You will need to enable full web access for the phone in the CM to be able to make changes on the 7921/7925 via the web.
Syslog is under the trace settings configuration.
Granted I have a much simpler wireless setup (the APs are autonomous), I was having a similiar problem where there would be a brief skip in the audio when roaming to a new AP.  It turned out by turning on "admit-traffic" under the "dot11 ssid" section of the config it fixed my problem.  It's worth a shot if you don't already have that configured.
Hall of Fame Super Gold
Don't go to the "21a" autonomous IOS because the sub-command "admit-traffic" has been removed.  I had to roll-back because my 7921/7925 just went haywire.
954
