VoWireles design and best practise
We have 34xAP (1130, 1240) 2x 4402 WLC and 60x7921 with 1.3.3.
1.Is better use WLC 5.2.193.0 or upgrade to 6.0.196.0?
2. Is it possible use WPA2 + AES + CCKM?
3. Which security setting is best for use for 7921 and fast roaming?
Hall of Fame Super Gold
Re: VoWireles design and best practise
I never recommend using the 5.X.  It's full of bugs.
It is.  Upgrade the firmware of your 7921/7925 to 1.3.4.
Follow the deployment guide.
Cisco Unified IP Phone 7921 Implementation for Voice over WLAN
http://www.cisco.com/en/US/customer/docs/solutions/Enterprise/Mobility/vowlan/41dg/vowlan_ch10.html
Don't forget to rate our posts.  Thanks.
Version 1.3.4 on 7921 I tested but there was problem with pover consuption. During 4 hours was phone discharged.
Jan, you are correct. It because 1.3.4 stays at 17 dbm all the time. I understand Cisco is release an update to fix this issue end of month ... Maybe one of the Cisco guys here can comment ...
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
Thanks George (+5).  Can't wait to test this out!
Thank you for the rate leo!
You deserve it!  At least you're in the Leaderboard now!
Hi Jan,
You can get a temporary fix firmware, version 1.3.4.0.2, from TAC.  Tell `em that George sent you.  Ha ha ha ...
The last bit is just a joke.
LOL
Jan,
Please mark this Question as "Answered" if you got the correct information from Leo and George.
thanks,
Vinay
Thanks & Regards
1091
