08-18-2014 02:52 PM - edited 07-05-2021 01:23 AM
Hi All,
From reading current config guides etc I understand that VoWLAN should be fine with FlexConnect if APs at a given FlexConnect enabled site are in a common FlexConnect Group
I also seen articles including the following that recommend against the use of FlexConnect for relianble voice.Noting this article is now a couple of tears old.
What is the current postion on FlexConnect with Voice and what are peoples experiences ?
I have a customer with a few remote sites each with under 10 APs that I'm considering FlexConnect of their central controller howver voice is required these sites.
Many Thanks,
Leon
08-19-2014 03:00 PM
If you do your survey right, tune RRM, have all the phones staticly connected on the 802.11a only with the latest software release and QoS is end-to-end in place, you will be fine.
Carefully choose your AirOS release, I did have some issues with one-way audio before the 7.4.121 release. In one deployment I even used WPA2 AES with PSK's but did not experienced issues do to bug CSCtt38270.
09-04-2014 04:01 PM
Here is the latest 7925G deployment guide [1.4(5)SR1 Release)].
If you follow these best practices & use your branch office AP in FlexConnect AP group & CCKM enable on the WLAN you should be fine. In FexConect mode still layer 3 roaming of local switched WLAN is not supported. Below is the latest 8.0 WLC config guide with respect to FlexConnect
Rasika
**** Pls rate all useful responses ****
