WDS and 2 Aironet AP's with local radius
Here is what I would like to do and I'm wondering if it is possible. I have 2 Aironet AP's in a lab environment. The two are mirrors of one another. Both have two vlans. Vlan 1 on both used local radius, a TKIP cypher,EAP. Vlan 2 uses WEP. Can I set one as the WDS and one as the AP and AP to the local radius on the WDS device? I tried this and it really messed things up to the point that no I'm unable to anthenticate. Just a note. I've implamented CCKM on all devices involved and only the SSID utilizing TKIP is being included in the configuration. What I really want to do is authenticate agains the local radius on the WDS device. Thanks, Shawn
1 REPLY
Anonymous
N/A
Re: WDS and 2 Aironet AP's with local radius
This setup can be implemented. Have a look at the following configuration example document which depicts a scenario similar to your requirement.
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_configuration_example09186a008059a559.shtml
367
