Wireless Multicast on WLC 5508 release 7.5
Hi, i'm working with WLC 5508 with about 60 Lightweight APs, I want to use an application on the Laptops connected to Wireless network via Multicast. Multicast is working fine in the wired network, but I need to work with the application in Wireless network also.
The configuration of Multicast on WLC is set as following:
Controller > AP Multicast mode: Multicast, IP: 239.0.238.1
Controller > Multicast: Enable global multicast mode is check, also the IGMP snooping
Wireless > Media Stream: Multicast direct feature is NOT enabled
The WLC is recognizing the Multicast groups (239.0.208.0, 239.0.208.1, 239.0.208.2 and so on).
The SSIDs not have enabled Multicast Vlan Feature, but I did enabled it to make tries but isn't working.
WLC sees the device directly connected via CDP (Switch 4510) but it see it with the IP address 192.168.1.1 belonging to Interface Vlan 1 on 4510 switch, but the Vlan belonging to WLC is Vlan 98 and has an IP address of 172.30.98.1, I don't know if it may cause some problems.
Here is also the configuration on switch 4510 corresponding to WLC:
interface TenGigabitEthernet5/1
description TO WLC
switchport mode trunk
interface Vlan98
description VLAN AP_WLC
ip address 172.30.98.1 255.255.255.0
ip helper-address 172.30.1.2
ip directed-broadcast
ip pim sparse-dense-mode
ip route-cache same-interface
no ip split-horizon
I appreciate your help with this issue. Thank you.
1 REPLY
VIP Purple
If your multicast application required bandwidth (like video stream) then you SHOULD configure "video stream" feature to things work properly.
Here are some useful info on this topic which I tested on wlc 7.0.116.0 version, still concept should be same & it may be useful to you.
1. Wireless multicast not working, why ?
http://mrncciew.com/2012/12/20/why-wireless-multicast-is-not-working/
2. Understanding Video Stream feature
http://mrncciew.com/2012/12/24/understanding-videostream-feature/
3. Configuring Multicast on WLC
http://mrncciew.com/2012/11/17/configuring-multicast-on-wlc/
Rasika
**** Pls rate all useful responses ****
1192
