Wireless Radio Hwic-AP-AG-A, not supported/disabled in this slot
Hi All,
Need a little help !
I have a 2811 router running code :c2800nm-ipvoicek9-mz.124-13b.bin".
I recently bought a Hwic-AP-AG-A, which is supported on a 2811.
However, when I install the card into a Hwic slot, & execute a Sh diag
it shows the Module not supported / disabled in the slot.
Can someone explain why.
Details below.
WIC Slot 1:
        Unknown WAN daughter card
        WIC module not supported/disabled in this slot
        PCB Serial Number        : FOC09363ZMA
        Hardware Revision        : 1.0
        Part Number              : 73-9388-03
        Board Revision           : A0
        Top Assy. Part Number    : 800-25210-01
        Deviation Number         : 0
        Fab Version              : 03
        CLEI Code                : IPUIANDRAA
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Product (FRU) Number     : HWIC-AP-AG-A
        Version Identifier       : 01
        Unknown Field (type 004A): 00 00
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 30 39 33 36 33 5A 4D 41 40
          0x10: 04 91 41 01 00 82 49 24 AC 03 42 41 30 C0 46 03
          0x20: 20 00 62 7A 01 88 00 00 00 00 02 03 C6 8A 49 50
          0x30: 55 49 41 4E 44 52 41 41 03 00 81 00 00 00 00 04
          0x40: 00 CB 94 48 57 49 43 2D 41 50 2D 41 47 2D 41 20
          0x50: 20 20 20 20 20 20 20 89 30 31 20 20 D9 02 40 C1
          0x60: 4A 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hall of Fame Super Gold
Re: Wireless Radio Hwic-AP-AG-A, not supported/disabled in this
You need to use the "T" train IOS.
Please don't forget to rate useful posts.  Thanks.
Thanks Leo! 5+
I was just talking to a customer about this ... you just saved me the research!
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
Talk about perfect timing.  Thanks for the ratings George.
768
