WLAN design for 7920 phone
If I currently have an 802.11g network that has been optimized to support data devices at 36 Mb/s or higher (i.e., AP cells a little closer to maintain higher speeds) and I now want to add 7920 wireless phone support, do I have to re-do my site survey to optimize the WLAN speed for 11 Mb/s by spacing my APs further apart so that channels using the same frequency do not interfere with each other?
1 REPLY
Re: WLAN design for 7920 phone
With 802.11g radio, would want to set 11mbps to the basic rate and only enable 18-54 or whatever higher rates you want enabled.
Enabling lower rates will extend the cell and vice versa will reduce the cell.
So probably a good idea to re-check the coverage, noise, signal to noise ratios.
150
