WLC 4404 and AP 1242 Lwapp mode (not work)
I'm connecting the AP model 1242 with a WLC4404.
i'm using a layer3 cisco for DHCP for to pass the option 43.
I use the WLC in the LWAPP L3 mode.
I doesn't work. I've connected my pc with the AP and attach the file txt with a log.
log of the AP 1242
i think that the problem is
%LWAPP-5-CHANGED: LWAPP changed state to CFG
%LWAPP-3-CLIENTERRORLOG: Config Request Timer: did not recieve config response (controller - WLC-1)
%SYS-5-RELOAD: Reload requested by LWAPP CLIENT. Reload Reason: DID NOT GET CONFIG RESPONSE.
%LWAPP-5-CHANGED: LWAPP changed state to DOWNXmodem file system is available.
flashfs[0]: 8 files, 3 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 5404160
flashfs[0]: Bytes available: 10594816
flashfs[0]: flashfs fsck took 26 seconds.
Base ethernet MAC Address: 00:1d:a1:ce:39:dc
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
Loading "flash:/c1240-k9w8-mx.124-10b.JA/c1240-k9w8-mx.124-10b.JA"...################################################################################################################################################################################################################################################################################################################################
File "flash:/c1240-k9w8-mx.124-10b.JA/c1240-k9w8-mx.124-10b.JA" uncompressed and installed, entry point: 0x3000
executing...
and the AP go in loop.
I can try to connect a DNS server , but there aren't any change.
What can i go ?
thanks for your help
FC
1 REPLY
Re: WLC 4404 and AP 1242 Lwapp mode (not work)
That certainly is in interesting one!
Few things though...
1 - What version of code are you using on the WLC?
2 - Is it possible to get a copy of the corresponding logs from the WLC?
3 - Are there any firewalls / ACLs between the AP & WLC?
My initial thoughts are;
A - Buggy code. Lots of people like to stick with old code and I really don't know why, so try upgrading this.
B - Comms error. The AP is certainly contacting the Management Interface, but I'm not sure about the AP-Manager interface. Double-check the config of both interfaces.
C - Comms restriction. Is there anything that would stop the AP using UDP 12,222 - 12,224 between its self, and the WLC Management & AP-Manager interfaces?
Take a look and get back to us.
Richard
431
