12-01-2007 06:48 AM - edited 07-03-2021 03:02 PM
I was wandering if you already asked yourself about the nature of the wmm(802.11e) technique from the performance point of view and especially its relation to qos policing/shaping. The wmm normally is giving access with priority to voice /video applications resulting in more latency more loss for best effort and background access categories. Assuming a scenario where you are not having any static call setup limitations ( via CAC ) should we consider any shaping/policing that would limit the bandwidth of voice category or guarantee the bandwidth to best effort of background flows. Thanks for your comments in advance.
Kind regards,
Michal
12-07-2007 02:04 PM
It would be better to consider shaping that would limit the bandwidth else best effort traffic would be overridden. Have a look at the link http://www.cisco.com/en/US/docs/wireless/controller/3.2/configuration/guide/c32wlan.html#wp1085045 before deploying.
12-08-2007 05:25 AM
Hi , thank you for your feedback and it looks like in certain deployment ( for example if the client requires having voice and data allowed on the same ssid ) we should look into shaping to assure the coexistence of both services.
BR ,
Michal
