WPA2 AES PSK
john.rossi.st
Hi Experts,
I see that these are the commands for 802.1x, but what is the PSK version of this command?
wlan security wpa wpa2 ciphers aes enable 1
wlan security wpa akm cckm enable 1
John
2 Accepted Solutions
Add this line
config wlan security wpa akm psk enable
Try this:
wlan create 2 contractor contractor
wlan radio 2 802.11bg
wlan interface 2 int143
wlan security wpa akm 802.1x disable 2
wlan security wpa akm psk enable 2
wlan security wpa akm psk set-key ascii Cisco123 2
wlan peer-blocking drop 2
wlan chd 2 disable
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
7 Replies 7
George Stefanick
Is this what your looking for ?
(WiSM-slot8-2) >config wlan security wpa akm psk set-key
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
"Im like bacon, I make your wireless better"
That seems to be correct, but I get a strange error when I try to deploy it.
wlan security wpa wpa2 ciphers aes enable 2
wlan chd 2 disable
(5508-DC) config>wlan security wpa akm psk set-key ascii Cisco123 2
ERROR: PSK and/or FT-PSK should be configured on WLAN 2
(5508-DC) config>wlan peer-blocking drop 2
(5508-DC) config>wlan chd 2 disable
Any thoughts why the error?
Best Regards,
John
Add this line
Actually, just tested it and I get the same error. Any other thoughts?
Try this:
wlan chd 2 disable
Scott
-Scott
Scott,
You are truly the man... Godlike!
Are you a Wireless CCIE?
wlan chd 2 disable
Best regards,
John
hahaha... I wish... maybe one day when I can focus.... hard with kids running around:)
I like to tinker around!
Scott
-Scott
