Wireless - Mobility
Connect with peers and Cisco on all aspects of wireless tech including security and network management, LANs and indoor and outdoor access points.
Browse the Community
Activity in Wireless - Mobility
Recommendation Software ISE
Hi EveryoneOur client for ISE software still uses version 2.6 with pach 10,We will upgrade the software to 3.1 with patch 8, please provide a recommendation link from CiscoI'm afraid that if I downloaded it wrong it would have fatal consequencesThank...
u-boot C9164 APs
Hi,with some Catalyst C9164 APs we have the problem that the image is corrupt.https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/220443-how-to-avoid-boot-loop-due-to-corrupted.htmlCan the C9164 APs even u-bo...
JanLev by Level 1
  • 70 Views
  • 2 replies
Clients only connecting 11a/11g
We currently have two 9800 WLCs serving our schools. Their configs are virtually identical. When clients connect to one specific SSID on 9800 A, they'll connect at expected speeds using 11ac or 11n protocols. However, when clients connect to the same...
WLC 9800 Process iosd Eror
hello,i'm running wlc9800-40 17.6.4 version and i'v got this errorSeverityProcess NameMessageCriticaliosdApr 10 23:47:04.326: %IOSXE_QFP-2-LOAD_RECOVER: Slot: 0, QFP:0, Load 45% recovered.5 secs traffic rate on QFP: Total Input: 13034 pps (13.0 kpps)...
RoeyF by Level 1
  • 229 Views
  • 11 replies
Cisco Catalyst 9800-40 Wireless Controller
Hi all,I am new to Cisco WLC.I have Cisco Catalyst 9800-40 Wireless Controller and it is running on software version 17.3.4c.I am told to upgrade to the latest one and I have no idea which is the latest one with no bug in it. I tried to download the ...
lachimip by Level 1
  • 331 Views
  • 16 replies
9800 Guest Anchor Design
I am trying to understand Guest Anchoring with the 9800 Controllers. In the 5500 series WLCs you had to access the WMI from the inside network through the firewall to the Anchor Controller Mgmt Vlan on a DMZ.  Then create another sub-interface on the...
Resolved! Cisco 9120AXE EWC Client Setup
I'm looking to add another 9120 to connect to my my 9120 running EWC. It seemed to join the EWC and it shows up as an online AP, but it shows as standby, like it's another standby EWC. It also looks as if it has both the AP and the EWC image.I was lo...
emuman100 by Level 1
  • 1720 Views
  • 25 replies
Why, when AP joins EWC, the AP gets an EWC image
Hi all,This is my first time working with EWC, and I'm a bit confused about the joining process of the access point.First, here are the hardware components I'm working with:Access Point: C9120AXE-EEWC: C9130AXE-EWC-EVersion: 17.9.4aI don't understand...
Shiden by Level 1
  • 1016 Views
  • 18 replies
Poor 5Ghz throughput - 9800 / 17.9.4a / 1800-series APs
Hi,Per the title, I've got an issue with 5Ghz clients that have good signal strength because they are sat almost underneath the AP (1832 APs) yet but struggling to get more than 1Mbps throughput.  I can see the channel utilisation is over 50% but zer...
Resolved! OID - AP count
Hello,I'm looking for SNMP OID for vWLC 9800 that allows monitoring AP count connected to WLC. Is this possible? Does WLC return such counter via SNMP ?
jakubgm by Level 1
  • 174 Views
  • 6 replies
Can I change the regulatory domain for our new CW9164I-ROW AP?
We have a 9800-CL Wireless Controller running 17.12.2.  We just got a new CW9164I-ROW AP and its registered by the operational interfaces are down due to a regulatory domain error.  Is there a way to change the regulatory domain for the access point?...
Cisco c9120axi-e webui problem
Hello,I have a Cisco c9120axi-e access point, and I want to configure it, but the SSID is not displaying. I connected it with a router, it got an IP address, but the web interface of the access point is not accessible with its IP address.Best regards...
m-ch by Level 1
  • 175 Views
  • 7 replies
Top Experts - Last 30 Days
