WAP4410N force LAN Speed workaround
ktchan
Agreed that forcing the LAN port speed to 100Mb is a bad workaround.
The better temporary solution (you may be an expert) is for the WAP to
advertise the capability of 100Mb FDX in autonegotiation.  I believe
autonegotiation will then bring the connection to 100Mb AND full duplex.
Autonegotiation advertisement is pretty powerful.
Bottom line I also agree the WAP4410N should not stop responding
in any conditions especially in Gigabit mode since a standard feature
of the WAP4410N is the Gigabit Ethernet LAN interface.
KorneelBullens
I set the autonegotion advertisements on my switch to 100 half and 100 full, this worked like a charm.
I still think this is completely unacceptable, I bought these switches especially for N capabilities, and sharing at high speed. I guess that isn't happening till a proper fix is deployed.
