Showing results forĀ
Search instead forĀ
Did you mean:Ā
WRVS4400N external IP blocking(banned),as???
19750108goda
5 Replies 5
19750108goda
Yes and not get a response???
Give the link to read about.Thank
Or no one knows the answer?????? and this model can not block external IP block !!!!
ever get an answer???
Leo Laohoo
What are you trying to do exactly?
There is a game server in the server network,with specific port and a user on the server which is disabled(deleted) but HE still tries to connect to his account.He needs to be blocked(his IP)on the router that he would not make additional load to the server.
Thank
Problem solved, it is necessary to create two rules
example:
http://i50.tinypic.com/35anqj4.png
