01-16-2015 10:30 AM - edited 07-05-2021 02:17 AM
I need to know if I can use the AIR- ANT24120 antenna on the access point model AIR-CAP1602E-T-K9 ?
01-16-2015 12:08 PM
You can, but you would need 3 and you would also have to disable the 5ghz radio. If you really want to utilize the 1602e, then look at:
AIR-ANT2451NV-R
AIR-ANT2544V4M-R= (don't need to use the other lead)
-Scott
04-09-2015 06:04 AM
Adding to Scott:
These antennas are supported on the 1602E:
