05-08-2012 03:32 PM - edited 07-03-2021 10:08 PM
Hi all;
I have an issue with WLC , the WLC cannot delete the information of the client when it jump to new SSID , it mentains the old information, it connect with the second SSID but it details (IP address and interface) as it is connected with the old SSID, although the fast SSID change enabled , um runnning
AIR-CT5500-k9-7-0-116-0.aes
05-09-2012 08:29 AM
Did you enable fast ssid change from the WLC? This will clear the table on the WLC before the client is able to connect to the new ssid.
05-12-2012 10:47 PM
yes enabled
05-13-2012 01:23 AM
show client detail < mac address while connected to the old ssid>
Try to connect to another ssid and have the following outputs:
debug client
show client detail < mac address > every now and then until the client appear
in the RUN state machine in the debugs output
In the meantime try to disable session timeout on the SSIDs between which the client is trying to change connection.
Also check this caveate which approximately describes similar symptoms:
WLC keeps ghost client entry | |
Symptom: ==================== WLC keeps ghost client entry if network between WLC and HREAP is unstable.Condition: =========== network between WLC and HREAP is unstableComponents: =========== H-REAPWorkaround: =========== We have some workarounds to delele ghost entries. - disable/enable WLAN - configure session timeout |
