Cisco 877W Wlan no more working.
kemaldede
Hi@ll,
im new to Cisco and his IOS. I config the 877W with SDM and CLI and have build a running config. But my problem was that wlan clients can acces the wan but not the lan. So try to change over webinterface that wlan are in vlan1.
i restart and have no more wlan and in the config i have now the subinterface Dot11Radio0.1 ? How can i Delete this? I try it from SDM and Reboot but is everytime in the config again.
My config looks like this
description WLAN
no ip address
encryption mode ciphers tkip
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2462
station-role root
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
encapsulation dot1Q 1 native
shutdown
no cdp enable
bridge-group 1
kemaldede
hi@ll,
no body have a solution? How i can remove the subinterface Dot11Radio0.1 without that it worked.
Thanks.
Not applicable
Coudl you verify the SSID details, also Are you using WPA ?
Hi rroas45,
thanks for your reply.
My ssid details are working before of the change and yes im using wpa. I make the change because i can not acces to my lan clients from wlan. I make it wrong and i can not make return config because im new to cisco and his ios. Here are my ssid details.
dot11 ssid XXXXXXX
vlan 1
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii XXXXXXXXXXXXXXXXXXXXXX
no ip source-route
ip cef
Regards Kemal
