Cisco AP LED Status
bouchal-38
I would like to know if someone can tell me what means the LED status?
When it is blinkink, or OFF?
Rightnow, i have the LED OFF, bur the SSID is working, the broadcast is working...
What does it mean?
Tx,
B.
Scott Fella
You can enable and disable the LED on an access point if you want. Here is a link and most likely why your AP works but is in a disabled state. I'm assuming it's a lightweight AP
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-4/configuration/guides/consolidated/b_cg74_CONSOLIDATED/b_cg74_CONSOLIDATED_chapter_010000001.html
-Scott
Scott Fella
For autonomous, the command is led display off or led display dim.
-Scott
Hi ,
Please refer the following doc. for more information.
https://supportforums.cisco.com/docs/DOC-5377
Let us know if you are looking for anyting in particular ( any AP model)
Victor V
*****Help out other by using the rating system and marking answered questions as *****Answered"*****
Regards Victor V *****Help out other by using the rating system and marking answered questions as *****Answered"*****
manassin
What is the model of the AP
Is it a Standalone AP or LWAP.
You can refer to the following link for the LED status:
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/1200/installation/guide/1200-TD-Book-Wrapper/120h_7.html
Check table 7-1
It is for 1200 series AP.
Please let me know the exact model of your AP.
Thanks and regards,
Manas Pratap Singh
