Are you using key-management (WPA, CCKM)?
If so, put the phone into AKM mode.
CCKM is only supported using WPA on the WLC.
7920 only supports TKIP encryption.
Ensure 3.02 firmware for the 7920 is used.
If that is configured correctly, then would look at the RADIUS failed authentication log to troubleshoot further.
