07-17-2009 02:12 AM - edited 07-03-2021 05:50 PM
A customer has a wifi system with Psion Teklogix AP. He wants to expand the coverage by adding a couple of AP autonomuos mode cisco and asks me if the roaming works correctly.
The security is WEB128.
I think that there are no problems.
What do you think?
Regards.
MirkoS.
07-17-2009 04:49 AM
Since 128-bit WEP is standards-based, there will be no trouble as long as the Psion APs are WiFi-compliant, which they should be. Roaming will work fine as long as the SSIDs and the WEP keys are the same on all APs.
You might want to advise your customer to consider upgrading to WPA2-PSK, which is very similar to WEP but far more secure. He might be unable to upgrade if he has legacy clients that aren't capable of WPA, but if there's nothing holding him back then I would definitely consider moving that direction. That's assuming the Psion APs are new enough that they can handle it.
Jeff
07-17-2009 07:19 AM
Jeff.
If the security is a WPA with TKIP, there is a problem in roaming phase?
Regards.
MirkoS.
07-17-2009 07:54 AM
Hi MirkoS,
Sorry for being confusing. As long as you're using the same security on an SSID on each AP, your roaming will work fine. WiFi includes standards-based security which will allow roaming to occur between different vendor equipment.
So WEP128, WPA-TKIP, and WPA-AES will all work fine as long as each AP is configured the same.
07-17-2009 08:00 AM
Ok, jeff.
Thank a lot.
MirkoS.
