cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Wireless MAB guest access issue - DHCP_NOTIN_POOL
yong khang NG
Level 5
Level 5
Hi all,
I am doing Wireless MAB guest access with the use of these component:
a. WLC 2504, code version 7.6.100.0
b. ISE code version 1.2.0
DHCP server was host at WLC.
Problem is guest after authentication success, it won't auto trigger the CoA, this process need to manually reauth at client side. I try this on iOS 7.0.4 and window 7 ultimate, they all behave the same.
I grab some log look fishy on WLC, is it anything hints from this?
Attach
03. guest authentiation process
Noel
0 RESPUESTAS 0
Vamos a comenzar
