WLC 2006 INTERNAL DHCP FOR GUESTS CLIENTS
tkuzma1022
I would like to use the internal DHCP to issue ipaddress to the guest wireless clients.
However; when i setup the wlc internal DCHP scope and try to connect to the wireless guest vlan the WLC debug DHCP reads ...forwarding to 192.168.255.2 which i have listed as the gateway to the pix
any examples on how to do this would be great.
here is what i have for the dhcp scope:
Dhcp Scope Info
Scope: Guest.Data.DHCP
Enabled.......................................... Yes
Lease Time....................................... 86400 (1 day )
Pool Start....................................... 192.168.255.17
Pool End......................................... 192.168.255.30
Network.......................................... 192.168.255.0
Netmask.......................................... 255.255.255.0
Default Routers.................................. 192.168.255.2 0.0.0.0 0.0.0.0
DNS Domain.......................................
DNS.............................................. 0.0.0.0 0.0.0.0 0.0.0.0
Netbios Name Servers............................. 0.0.0.0 0.0.0.0 0.0.0.0
Here is what i have for the wlan
WLAN Identifier.................................. 2
Network Name (SSID).............................. Guest.Data
Status........................................... Disabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Number of Active Clients......................... 0
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. Infinity
Interface........................................ guest.data
WLAN ACL......................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Enabled
Quality of Service............................... Silver (best effort)
WMM.............................................. Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
IPv6 Support..................................... Disabled
--More-- or (q)uit
Radio Policy..................................... All
Security
802.11 Authentication:........................ Open System
Static WEP Keys............................... Disabled
802.1X........................................ Disabled
Wi-Fi Protected Access (WPA/WPA2)............. Disabled
CKIP ......................................... Disabled
IP Security Passthru.......................... Disabled
Web Based Authentication...................... Disabled
Web-Passthrough............................... Disabled
Auto Anchor................................... Disabled
H-REAP Local Switching........................ Disabled
Management Frame Protection................... E
Matthew Fowler
Could you please provide the guest.data interface configuration? Is the DHCP server listed as the management address?
If so, I think this is working as intended. The management will be on a different subnet, and seeing as the WLC is a layer 2 device, it has to forward to the gateway.
After it forwards to the gateway, what happens?
tkuzma1022
when i try to assocate the dhcp scope to wireless.guest.data interface using 192.168.255.1 which is the ip of the that interface it will not let me. I would have thought since i was using the interal dhcp that the .1 address would be the dhcp scope address also. i can assign 192.168.255.0 or 192.168.255.2(gateway)if i use .0 or .2 the dhcp request (discovery) process starts and then will forward to .2 (gateway) and never assign an address. the only thing that happens is that the client wireless interface will get 255.255.255.255 for a few seconds then go away.
what i am trying to accomplish is to connect the wlc port 2 directly to a pix 506 which goes to the internet so the guest traffice is not on our vlan.
any other suggestions on guest vlans would be appricated....
Tom
Interface Name................................... wireless.guest.data
IP Address....................................... 192.168.255.1
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 192.168.255.2
VLAN............................................. 150
Quarantine-vlan.................................. no
Physical Port.................................... 2
Primary DHCP Server.............................. Unconfigured
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
AP Manager....................................... No
Scope: wireless.guest.data.dhcp.server
