09-14-2009 08:02 AM - edited 07-03-2021 06:02 PM
Hello all
I'd like to know if there is a way to enable bonjour traffic on the WLC 4400 series. we have some apple application that uses bonjour traffic that we can't use since we implemented the WLC, when we had the stand alone AP 1131, 1231 those apple application worked great, however when we centralized the control those applications doesn't work any more
please help
Solved! Go to Solution.
09-15-2009 05:18 AM
You will have to enable multicast on the controllers and use a global port 239.x.x & above and it will work fine.
09-14-2009 03:11 PM
Errr ... unless you have ACL set, the WLC won't stop Bonjour traffic.
DO you have a firewall?
09-15-2009 05:18 AM
