ā03-08-2015 09:58 PM - edited ā07-05-2021 02:40 AM
Hi All,
I have recently setup two Cisco WLC 5508 (HA) at customer premise, customer requested to use RADIUS as the user authentication, the setup is successful but anyhow, after authenticated and granted with IP address via their DHCP Server, user found the IP setting on his laptop, and he is asking why the DHCP Server IP is 1.1.1.1? Not the real DHCP Server IP. When he used wired connection, the DHCP Server IP he gets is the exact DHCP Server IP. He is asking me to change the DHCP Server IP to reflect the real DHCP IP instead of 1.1.1.1 in WLC. Is it possible?
Another request from my customer is he wants to assign a specific port number for the WLC HTTPS access.
The common web access is https://<WLC IP ADDRESS>
What he wants is https://<WLC IP ADDRESS>:9191
I couldn't find any configuration on port number in WLC, may I know is it possible to configure this?
Thanks.
ā03-09-2015 03:57 AM
I don't believe the port can be changed at all. The reason you see the VIP address is because dhcp proxy is enabled. If you disable that, then you will see the dhcp server address. Dhcp proxy is required if you want to use the WLC as a dhcp server. Later WLC code allows you to set this per wlan.
-Scott
ā03-09-2015 04:46 AM
Hi Scott,
So meaning to say the port number cannot be changed at all?
ā03-09-2015 05:11 AM
I've never seen the port changed. On the 1.1.1.1 if you disable proxy on the wlc you will need to add helpers on the svi.
ā03-09-2015 05:39 AM
Yes that is correct... Can not be changed.
-Scott
ā03-26-2015 07:25 PM
Controller->Advanced->DHCP (Note: Setting the DHCP proxy via the GUI is not available in all versions)
Or via the CLI:
Config dhcp proxy enable Save config
