Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
[add licenses to ASR9001 cluster]
Dear CSC:
I have a cluster out of 2 ASR9001 and have the following questions regarding license installation. I'll try to make my questions of the yes or no type answer.
- i know the nv-cluster license is required, per the installation guide it's recommended that the license is generated by using the S/N of rack0. is this enough?
- should i install a second nv-cluster license generated by using the S/N of rack1?
- i purchased 2 iVRF licenses, one for each, rack 0 and rack 1 in this cluster. should i install just one with rack0 S/N?
- should i generate  second ivrf license by using rack1 S/N and install that one also?
- i already installed the rack0 S/N ivrf license and already configured a working vrf (the vrf is operational), but when i show the licenses it doesn't show as active/operational, is this correct?
RP/0/RSP0/CPU0:XXXXXXX(admin)#show license
Wed Jan 15 18:47:35.532 CST
FeatureID: A9K-NV-CLUSTR-LIC (Slot based, Permanent)
  Total licenses 1
  Available for use         1
  Allocated to location     0
  Active                    0
  Store name             Permanent
  Store index               1
    Pool: Owner
      Total licenses in pool: 1
      Status: Available     1    Operational:    0
FeatureID: A9K-iVRF-LIC (Slot based, Permanent)
  Total licenses 1
  Available for use         1
  Active                    0
  Store index               2
    Pool: Owner
RP/0/RSP0/CPU0:XXXXXXXXX(admin)#
RP/0/RSP0/CPU0:XXXXXXXXX(admin)#show run
Wed Jan 15 18:48:09.293 CST
Building configuration...
!! IOS XR Admin Configuration 4.3.2
[snip]
nv
edge
  control
   serial XXXXXXX rack 0
   serial YYYYYYY rack 1
license A9K-iVRF-LIC
location all
license A9K-NV-CLUSTR-LIC
location 0/RSP0/CPU0
end
c.
338
